So I am trying to find a lift kit for my new truck, but am having trouble finding a kit that doesnt require the following:
  • Doesnt use blocks in the rear.
  • Doesnt require the cutting of the crossmember. (for instance Profab and Fabtech)
  • Doesnt void warranties, which is why I dont want to cut the crossmember.
  • Gives me between 3 and 6 inches
Thats all I can think of for now. If you have any suggestions please let me know.
For what it is worth it is a 07 Taco DC w/ TRD offroad package.
Thanks in advance!
-99999
donahoe coilovers+allied spindles will be around 6" and some dakars for the rear with donahoe resi's, youre good to go.
If he has got the $$$$$$$ to do that. But that is your best bet right there.
spindles wont work on a 4wd, but he didnt list prerunner or 4wd.
If you dont want to cut you are limited to about 2-3" of suspension lift. Then if you HAVE to go taller you will have to do a body lift also. The way toyota designed the front crossmemeber you cannot do a bracket lift (any susp over 3") w/out cutting. Its been that way since 95.5.
