Hi I have a 07 Tacoma with the 4.0 that goes into what the dealer calls limp mode the code says cyl 6 miss fire it's been in and out of two dealers for a yr now they tried injectors cats coils plugs and I put a new computer in and still the same cyl nothing help then they say they did a leak down test and said the motor was bad so I got another one they did the test it was good put it in same thing has anyone came across this problem thanks
Does. it. do. it. with. the. A/C. on ?
Maybe bad compressor, or torque converter, causing the crank to speed up or slow down, making the engine/computer "think" there is a misfire.
The engine will run flawlessly, but an outside force causing a wobble wobble will give misinformation to the ecu.
No it dose it with or without the ac on
When it dose it it will go into limp mode and run like crap no power at all
I have to turn it off then wait a min start it back up and it's fine
