1 - 20 of 23 Posts
I use to get 20 mpg (but some arse drilled a hole in my gas tank j/k) since regular gas up here in b.c canada is 97 cents a liter, ever since i went with different rims and my tires stick out 2 inches past the fenders my economy went for shat as well.
The price of having fun WORTH IT.
Just checked mine yesterday. 17.7 mpg with the 3.4 v6. SAS'ed and 35's. with 4.88's. Steel flatbed rocksliders and custom front bumper. All that steel causes more work=less mileage. Gotta get those gears.
Check the air filter, fuel injector cleaner, clean the MAF and throttle body as mentioned above.
Chas said:
Im getting around 11.7mpg. I have the 3.4. I have 32's, but what the hell. This seems way too low. What should i be getting and what are you al getting?
Seems very low... I have 33's on the 3.4 (auto and have not re-geared). I get 15-17. 13-14 on wheelin' trips and the lowest ever, was towing a 4,7000 lb boat up to 7k feet and back, that was 10. Maybe need a tune-up?
· Long lost Taco Owner
13-14 wheeling? I am lucky if I get 8
Any CE light?An 03 shouldn't have that kind of a problem...hmmm. Time for a tune up, maybe? Try seafoaming then doing the iol, plugs, clean the MA sensor. Check your air filter.
Hows it running?
I should clarify mixed wheelin' and street...I have yet to use an entire tank on just wheelin' alone. Used a little more then a half tank on wheelin' and the rest getting home and got 13.
Discussion Starter · #16 ·
Hows it running?
Runs good, pulls real strong. Maybe take it in for the 30k serive a bit early and have them figure it out.
1 - 20 of 23 Posts
