anyone know if 15" wheels (stock toyota) will match up on an 03 or are there rubbing issues?
they'll fit fine...98% sure.
they work great.. i had em on mine
The stealership told me that the the 03 DC TRD 4X only came with 16"s. Was looking at 15's once.
truck ~n~ tow
Hey lazy... it's in the FAQ knowledge base "wiki"... LOL
{15" Wheels that fit 2001-2004 Tacomas}
All OEM Toyota 15x7 wheels that came on earlier Tacoma’s. These have the same BS as your 16” wheels. You can run up to 32x 11.5 with no suspension clearance issues
Well almost all ?
(in reference to certain calipers in the FAQ's)
This one uses a different one than all the rest: LIST D
95-04 4WD I4(3RZFE) XC
According to Wheelers Offroad, if you have VSC no 15" wheel will fit. You must stay with at least a 16" wheel. Added: I've read comments about the hub center changing size for 2003+. Toyota's part number for the axle hub is the same for 2000 through 2004. The investigation continues...
This information probably gives us a reason as to why some 15" wheels fit some Taco's and not others.
If this isn't making sense... check the FAQ's for more crap on this subject...
