1 - 3 of 3 Posts
My 86 Toyota 22r knocks at initial startup for about 2 -3 seconds then sounds fine. So do I need to replace the main bearings and rod bearings? Or could it be a stretched rod? Or a bad piston? What's a good solution? Full rebuild? New mains, crank, and rod bearings? And what other years of a 22r could I use for a bottem end rebuild ?
I've heard it's common on these motors to have piston slap when cold. Not sure if that's what your hearing but 2-3 seconds doesn't sound too bad to me. Maybe try a different oil.
Mine starts without a knock, then has a slight knock as it warms up and then fades away. Not terribly concerned about it, I've wheeled with a guy thats had a constant knock in his for years and it just keeps on going.
Put some Lucas Oil Stabilizer or something equivilent in to get rid of the dry start issue.
Sent from my SM-G928P using Tapatalk
1 - 3 of 3 Posts
