1 - 2 of 2 Posts
I am in the process of doing some work to my 96 taco and needed some advice. I already have the bilsteins for the front, but thought since I was going to the trouble I should replace the coils. I have checked on the net and ran across the northwest off road progressive and also considered the OME, but don't know which number. I have no lift on my truck it's a regular cab with the V6. I appreciate any suggestions. Thanks.
http://www.tacomaterritory.com/forum/showthread.php?t=898&page=3&pp=30&highlight=tundra+coil
http://www.yotatech.com/showthread.php?t=43942
http://www.yotatech.com/showthread.php?t=45522&highlight=tundra+coils
http://fastq.com/~sschaefer/Tundra_Coils.html
I ended up putting one upper (1/2") and one lower spacer (3/8") on the spring-strut. It works fine. About 1 3/4 lift. the ride is the same. rented two sets of spring compressors (four per coil) w/o problems. One set just isn't quite enough power to easily-safely make the change.
97 reg cab v6
1 - 2 of 2 Posts
