I need help!!! I was replacing my stock fan in my Tacoma with a flex a lite fan for more air flow at low RPM. as it goes, it was supposed to be a simple job but I have been hung up for two days now. My stock fan, and clutch will not come off no matter what I do!!!! I took the 4 12mm bolts off the fan, and ive taken the power steering belt, and the alternator belt completely off to take tension off the pulley and what not. no matter what the fan, and the clutch will not come off.... ive tried prying on it, beating on it with a hammer, rigging ratchet straps up to try and pull it off, using a whole can of pb blaster over night, freezing it by spraying duster gas upside down, prying with a flat head screw driver, i feel like I tried everything, any suggestions? I'm out of ideas.
I have new studs that the 4 nuts go on, so I even went as far as using vise grips to take all 4 studs out, and it still wont budge!!!!
