1 - 2 of 2 Posts
What are good tail lights to use on my Tacoma? Do I need to replace the lens? Do I need to rewire them?
Tail lights generally come as an assembly and aren't very much money. You can find aftermarkets on Amazon etc that work just fine. No need to re-wire, there is a plug behind the light housing after you remove the four screws. Double check that the new lights have the same wiring on the plug as stock...it should be the same but if it isn't then return it and try a different aftermarket.
1 - 2 of 2 Posts
