1 - 8 of 8 Posts
AsianTacoBoy said:
You better check on backspacing, brah. And, you are gonna need fenders for that. Or, a non islander approved....body lift. But if you use the body lift, be sure to leave some poi out for the menehune. They don't like body lifts.SHOOTS!! :xdevil:
anyone running 33x12.5's on 2.5" with glass fenders? Wondering if i'll be fine with 33x12.5's running donahoes set at 2.5" and 4.5" flare glass fenders.
· Going John Galt
RJ has ...works fine. He did have to, uh, 'clearance' the rear fenders, however ;)
I have the extended hoes w/ camburg UCA's and I there would be no problem with 33x12.50 only problem I can't think of is turning. Also I have glass on the front and I would recommend 3.5" flare, 4.5" flare doesn't look very good when its not extended.
i have the rought country lift...(i kno nothin really special..but for what i do its pretty good ish) and i clear 33x1250s with i think its a 2" or 2.5" in front cornfed and 3 inches in the back....i got 3.75 backspacing on the wheels...not too much rubbing..Pinch Weld pounding and it should be good to go
1 - 8 of 8 Posts
