Long or short side forward doesn't change shackle length/angle. Not too much has to be changed if you run short side forward. Basically what we are talking about is when you look at the leaf spring, there are the 2 eyes that hold the bushings and the center pin. So if you can imagine, setting your truck up with the short (leaf spring bushing center to center pin, aka the shorter of the 2 distances) side forward, it will pull your axle forward more than if you were to run long side forward (leaf spring bushing center to center pin, aka the longer of the 2 distances). Since most of us use leaf springs and a shackle in the rear (as opposed to a shackle at the front of the frame) when the truck flexes out, the stuffed tire will move backwards up into your firewall while the other drooped side will be away from the fender completely and moving forward. Basically all you get from running short side forward on your leaf springs is a better approach angle and the ability to stuff larger tires without getting into your firewall. Questions?
