My '98 2.7 was running real bad, CEL came on and I pulled codes 0300 and 0301 (misfires) . Took it to the dealer, confirmed codes, they did a compression test, and told me #1 cyl. was @50psi. Then they said it's probably valves, and for $2,500.00 they could do a valve job. I said thanks, but no thanks, did my own compression test and got #[email protected], #[email protected], #[email protected], #[email protected] Anyway, they weren't lying about the compression loss, but c'mon I can replace the whole head for alot less than $2,500.00, if it's even the valves. My question is, are there any other tests I can do to narrow the problem down? I guess it must be either valves, head gasket, or cracked head. Does anyone have some suggestions? Thanks in advance guys for any advice you can offer.
Jeff
NorCal
Jeff
NorCal
