A couple months ago my check engine light came on. I brought it in and scanned the code and it came up with a misfire on #1 cylinder. I was due for a tune up so I replaced plugs, wires, and fuel filter. I had low compression in #1 cylinder after all of that and the mechanic said there was quite a bit of carbon build up in the cylinder so he did a carbon flush on the cylinder. After that the compression came back up to normal. Everything was fine for about 2 weeks, then check engine light came back, scanned the code and came back with misfire on #1 cylinder again. The engine has steadily gotten worse, rough idleling, loss of power, etc. Any advice on what to do next would be greatly appreciated.
Thanks for the help.
