Had to replace my timing belt and a leaking water pump. The front is ready to be put back together, except I can’t find the torque specs for the fan bracket. There isn’t a single torque spec I can find for the top bolt and the nut on the right side of the fan bracket in the service manual. I also can’t find the torque spec for the nut that mounts the power steering pump belt adjustment bracket to the fan bracket. I know the power steering pump pivot bold torque and the lock adjustment nut once you’ve tightened the belt. I just don’t know about the other nut that tightens to the fan bracket. Any help would be appreciated.
