Was driving my 01 Tacoma V6 the other day and it just shut off. I pulled over and tried to restart it. It will turns over but want even try to fire up. I hooked my scanner up and it will not even communicate with the ECM anymore. Checked the power to the coils and the injector, I have 12V feeding them but no spark and no fuel. I tested the cam sensor, MAFS, relays and fuses, all are reading as the book calls for. I did not test the crank sensor!! I checked the timing belt and all's well with it. So I thought it's got to be the ECM, so I purchase one and low and behold I still have the same issues. Looking for some help from all of you out there. Any thoughts before I throw in the towel and send it to a shop?? Could it be an issue with the igniter? I don't even hear the fuel pump come on and off, I even took the fuel rail crossover off and turn the key to on and no fuel came out. Thanks for any help!
Same thing happened to me back in 2011. Truck died while driving. I didn't believe it could be the fuel pump at only 180K.
I changed the MAF, the TPS, IACV, and the ECM. No change. They all share the same circuit and I was getting weird readings from the IACV which is why I was throwing parts at it.
I eventually changed the fuel pump.
If you can't hear the fuel pump coming on then change it.
I would recommend Toyota OE only for the pump.
I had 3 Autozone pumps fail on me in 2 years.
This is spot on. Especially if you drive with the gas warning light on, or 1/8th tank or less. Possibly, but not probably, a very dirty fuel filter. It’s not that bad to drop the tank, and replace the fuel pump. You can even replace just the failed parts of a fuel pump and keep the sending unit and float you already have to save money.
I have a 2001 FSM but it should be good for ‘01-04 and very similar for the first half of first gens too.
