1 - 2 of 2 Posts
Howdy everyone,
My tacoma wont start. I just replaced the starter thinking thats what the problem was and the symptoms still remain the same! when i turn the key i hear one solid click, and thats it. i tried starting it 100 times at least and havent been able to get it started with either the stock starter or the new one i just installed. I also tried starting it while hooked up to another battery... no luck. anyone have any suggestions? my truck is pretty far out of town im hopin that i can figure it out on my next trip out there. its a 2004 3.4l tacoma and its always ran like a top, but it does have over 200k miles so i wouldnt be surprised if something went finally died.
Try putting the truck in neutral, if it's an automatic.
You can try jumping the starter relay. Pull the top of the relay off, get a piece of wire, and touch the two pieces until the truck starts. Make sure the truck is on the on position.
I had this problem in my 5 lug when it wouldn't start. Turns out the neutral starter switch was bad, and that's how I had to start it until I ended up getting rid of it before my last deployment......
1 - 2 of 2 Posts
