1 - 2 of 2 Posts
What's up guys.
I recently bought my first Toyota, a 2003 double cab that has been caged front to rear, battery moved to the bed, and other bells and whistles. The truck has some parasitic power draw which kills the battery in 4-5 days.
It's a full stock harness, but some things are not connected: abs/stock brake components, a/c and radio wiring, dome light, 3rd brake light, and EVAP stuff, plus more I'm forgetting. I'm wondering if maybe some of that could cause my power draw that any of you know of? I'm trying to figure out where to start when I have my next days off of work around Christmas.
Thanks for any help.
I assume it's automatic transmission. Kill battery in 4-5 days? With ignition switch in off position, try put 12 volt probe light between negative battery post and negative battery cable. Probe light will light up, then start pulling fuses, see if light goes out, probably can isolate circuit that causing battery drain.;)
1 - 2 of 2 Posts
