1 - 3 of 3 Posts
Can anyone please give me some real world advice on the driveability problems I may have if i install a supercharger on my 04 dbl. cab 4wd Tacoma. I live in MIchigan and have subzero temp. in the winter time. I also will be towing with the truck (it has the tow package). The load most often will be 1ton. I called TRD and they had no tech data exposing the truck with the above components and no advice. They test in Southern Cal. I would be grateful if anyone could refer me to a website or provide a company that would be able to help me. Thanks, Newbie
Gadget and others in this forum will have tons of info about that...i just ordered all my stuff (s/c,7th, URD AIC, 190 fuel pump, trans cooler, etc.) and hope to have it by this week and all the info about stuff like that can be found by searching the forum and listening to experienced member that will probably chime in...good luck and welcome
you might want to check out Gadget's site and urdusa.com
Gadget's site is http://www.gadgetonline.com/4run.htm
· Smoked Out!
As posted above, read gadgets site, and read it again. Get as much information on it as you possibly can. Be advised that a SC will need other components to make it run right and prolong the life of the blown engine. It is by far the best thing you can do to your engine to increase the power, but at the same time the most expensive.
1 - 3 of 3 Posts
