1 - 18 of 18 Posts
4x Innovations Tacoma sliders just got even better! 4x Innovations is proud to introduce Bolt On Rock Sliders for 2005 to 2014 Toyota Double Cab Short Bed Tacoma trucks and Bolt On Rock Sliders for 2005 to 2014 Toyota Access Cab Tacoma trucksWe took the ever popular and strong, durable Rock Slider set built from DOM tubing, engineered a bolt on mounting system, and fully weld all components. This creates the ultimate easily mounted Rock Slider kit. Mounting is achieved with two half length frame plates, covering nearly the entire side of the frame for maximum strength and support. Bolts use some of the existing frame holes, 2 new holes in the side of the frame, and 5 new holes along the bottom edge of the frame, per side. Side bolts come with large inner backing plate for maximum support. Bottom side bolts are mounted flush for a smooth sliding surface along the bottom of the frame.
This kit includes both the driver and passenger side sliders fully welded, ready to mount, and all required mounting hardware. Kits are $450 plus shipping. For more information or to order see this page on our web site.
looks like a solid product. i really like the plates that bolt to the frame as well as the welded nuts on the backing plates.
Those frame plates closely resembles the ones from AllPro lol...
Absolutely right, my bad..looks like the AllPro version has more beef
Discussion Starter #13
Actually there is significantly more support on the 4x Innovations mounts. You'll notice we are the only manufacture that runs the lower flange from the front ALL THE WAY to the back, supporting the slider where it is needed the MOST, The 4x Innovations rear most mount is supported just in front of the rear spring hanger, at the angled portion of the frame. This leaves the absolute minimum of unsupported slider possible. Also our front mount is supported on the lower side of the frame forward of the transmission cross member. I don't see either of those features on that other slider posted above.
Thanks for playing though.
Discussion Starter #15
4x Innovations now has bolt on sliders for the 05-2012 Tacoma Access Cab! Same Great price as the double cab.
Discussion Starter #18
2005-2014 access cab and double cab Tacoma Bolt On Rock Sliders are in stock and ready to ship!
1 - 18 of 18 Posts
