How did you do this on your '03? Would this apply to an '01 stock AM?FM/CA/CD player? Am I missing out on something here?Marc M said:Has anyone figured out how to get the "mid" setting on the new head unit. I did this on my '03 and just trained myself to turn the radio off before I turned off the truck.
I really miss the sound of my old radio...
what does it do?Marc M said:Has anyone figured out how to get the "mid" setting on the new head unit. I did this on my '03 and just trained myself to turn the radio off before I turned off the truck.
Marc
Cool! I now have "|| |" to mess around with! This should be posted in the Cheap Tricks section.Marc M said:With the truck on and the radio on, press and hold the tuning knob for approximately 10 - 15 seconds. You will hear an audible beep, now when you go back in to set the audio preferences it gives you the option for "MID" adjustment.
It will stay this way as long as you turn your radio off before you turn your truck off. If you happen to turn the truck off before you turn the radio off, all you have to do is perform the same sequence and it will come back....
Marc
Going to go try this on an '04.Marc M said:With the truck on and the radio on, press and hold the tuning knob for approximately 10 - 15 seconds. You will hear an audible beep, now when you go back in to set the audio preferences it gives you the option for "MID" adjustment.
Marc
You still get the credit for reviving it! Thanks...Marc M said:I am by no means taking credit for this mod, I actually got it from the old delphi site.
Maybe it just needed to be resurfaced....
Marc
Try releasing the knob right after you hear the beep instead of keeping it pushed in for another ten seconds? Just a shot in the dark but that's what it soudned like you did was held it a lot longer after you heard the beep. Maybe that "reset" it or something.Andrew123654 said:What exactilly do you do? I tried it on my 02... i puched the right circular knob in and held it there for like 20 seconds, about 10 seconds in it beeped and clicked back to the cd screen showing what song im on. I pressed the button for bass, treble, and so forth but couldn't find the mid feature.
Marc
