1 - 9 of 9 Posts
ive got a '06 pre-runner 2.7l 5-speed
33,000 miles
stock ride height
recent accuring problems:
-just replaced trans fluid with redline mt-90(75w90), second and third gears grind/crunch when cold and fully warmed
also tried amsoil syn trans fluid, same thing
installed bilstein stock replacement HD's
fckin shit ride:banghead:
lots of axel wrap on first gear excels, like washboard effect
right leaf spring feels blown (no to very little sag)
left feels perfect, is this possible with 33k miles?
suggestions?
33,000 miles
stock ride height
suggestions?
1. did you fill it enough?
2. you cant have "blown" leaf springs
maybe your clutch is going out. did you burn it up?
i put three quarts in there.
says 2.75 quarts but i jacked it up and added all of it.
possibility the clutch is going out, but its not consistant
but going overbumps on the left and right side are completely different, and this is very consistant. the left side is solid, will the right washboards over minor bumps and pot holes.
probably a blown shock then
thats intresting because i told my supplier to send me another one bceause i thought it was the shock; installed and i had the same problem.
Well, from looking at my friends, his isnt sagging. Take a look at the leafs and see if any of them are sticking out to the side. This is what his is like, so it causes the metal to kind of Bind up when flexing. It rides like Shit.
Discussion Starter · #9 ·
nothing extreme, just the bottom smallest leaf is sticking like a 1/4 inch out, but it looks identical on both sides.
im gonna put the stock wheels on it and take the mofo to the dealer, fckin stealershits
1 - 9 of 9 Posts
