1 - 11 of 11 Posts
Was wondering if any one knows what size injectors are on a stock 22re. Looking at a set of 460cc 44lb, i know theese are larger but will i need to modify any thing? Will my motor use much more fuel? Thanks for any input.
Its a waste of time and money unless you have the capability of adding an aftermarket engine management system (like Megasquirt). Pull your old injectors and have them cleaned/rebuilt and flow tested.
Ok thanks. Im not looking to replace with larger injectors but posibly just replace the old ones they do have 209k on them.
Just get your stock injectors rebuilt. larger injectors are only if you have ALOT more hp (supercharger/turbo). Without a proper tune, larger injectors would make your truck run pig rich or maybe not at all. Remember, more fuel = less power.
I just installed a set of flamethrower 4 hole and the
Resistor box delete, my truck starts and runs 100% better,
I can't say enough great things about them, took me 30 min to install..
I have a 87 22re... $100 for the injectors and $30 for the resistor delete..
2 year warr..
Link to the resistor delete please. Interested.
Sent from my iPhone using Tapatalk
1 - 11 of 11 Posts
