1 - 3 of 3 Posts
Toyota pickup parts 22r 22re 87-95.
engine parts:
****Engn Bldr Street RV head with 268* cam head features bigger ports, performance iron valve guides. Head has low miles, just pulled off running truck after the short block sold. Comes with 2 rocker assemblies, and a valve cover $500 *****
1)2wd radiator good condition, spare Toyota water pump, cooling shroud, and overflow bottle $110
2)3 power steering pumps, rebuild kit, 2 brackets, 2 reservoirs, pulleys, and high pressure lines $150
3)2wd brake booster $20
4)efi setup: upper and lower intake manifolds, 4 good injectors, thermostat housing, emissions equipment, air flow meter with adapter plate for k&n style filter, 2 fuel filters, ecu, harness, and most everything to convert a 22r to efi. $400
5)2 used clutches $25 each
6)Pace setter header, 2.5” piping, to a dumped spintech muffler, 02 sensor, also have cat that could be welded in. setup for a single cab but may work on extended cab. $300
7)trailgear ”bomb proof” style motor mounts and good factory 2wd trans mount $80
8)distributor, 2 caps and rotors, 2 sets plug wires, new ngk spark plugs $80
9)trailgear gm 1 wire alternator conversion brackets w/ 2 alternators 1 spare and 1 high amp(new) $150
10)used starter $30 like new
11)2wd 5speed transmission with hurst shifter, marlin crawler shift bushing, spare trans and case $200
12)Toyota 8” 4x4 axle with 4.88s and open diff. top and bottom spring perches. $450
13)complete ac system with new compressor and custom flex lines, condensor, etc. no parts from inside the cab. $400 comes with spare parts
suspension parts:
1)Total chaos uniball long travel kit. This was a standard uniball kit that was converted to 6 lug spindles and heim upper control arms for more strength and adjustability.
Uniball upper and lower arms
Heim upper control arms
Heim steering
Custom 6 lug 4x spindles
$1800
2)All pro baja 50t leaf springs 62". 12" frame over shackle. 4x4 8" axle with open carrier and 488 gears. $1050 for complete setup. $675 for springs, ubolts and shackles $450 for axle
also have some other items not listed, if your looking for something please just ask. all parts are in phoenix 6025714173
engine parts:
suspension parts:
Heim steering
$1800
1 - 3 of 3 Posts
