Probly one of the most simple things you can do is add a header to the exhaust system.......It is not gonna give you massive power gains but I did notice a positive difference in throttle response on mine.
i have also heard that cam swaps are a good low dollar mod but I have no first hand experience
I was looking at this awhile ago when I was looking to replace my aging 20R with a 22RE. Beyond swapping the stock cam out for an RV cam there's not a whole lot that can be done that qualifies as 'cheap'.
The conclusion I eventually came to was that $/hp it'd be cheaper to swap in one of the Tacoma engines. I'm not sure if the 2.7 will mate up with your tranny's bellhousing... for monetary reasons I never put alot of effort into finding a donor motor so the project is currently on indefinite hold.
I'm pretty sure some of the guys on Pirate4x4 have done such a swap, so they'd be able to tell you what you need if you're interested in it.
Exhaust, intake, cam, headwork. In that order. Don't expect any significant gains though. You can also try this from pirate4x4:
Horsepower – More Power
Thanks to DRM for saving this, and Tim for giving the advice.
Originally posted by DRM
"Ok ready, first pull off the efi fuse for a couple of seconds, then reinstall it. Grab some Autolite #65 plugs, and side gap them at .048. Set the valve clearance to .011 cold. Install the factory carbed thermostat {Pappy: it's a 180* vs. 190*). Adjust the AFM 3 teeth rich (under 5000 a.s.l.). Start the motor, let idle till you reach operating temp. Set the timing at 16* "not short circuted," {Pappy: about the same as 8* shorted} then take it for a putt, re check the timing, and enjoy. Leave the airbox alone, for it's not a cause of starvation on a stocker, and don't worry about the muffler for now. If you're going to modify the exhaust, start with a header, and 2.5" headpipe."
A follow-up from later that day:
"... you pull the EFI fuse to start the ECU's regathering of fuel mixture readings, because you are altering them via the AFM. The #65's are a hotter plug, and will in this case create a more efficient burn. You WILL NOT detonate when the timing is set 16* NOT SHORT CIRCUTED, because the end reading when short circuted will be 8* advanced. The afm adjustment enrichens the motor aproximately 3cc. This is necessary due to the timing advance, which requires a proper mixture."
I found the AFM 3 teeth to be too rich for my high desert home (driveway is 5200 ft) and have backed it down to 1 tooth rich.
