As soon as it dries out a little, probably early next week, I'll let you know.elgecko said:I've had good results with 27-front/24-rear on my extra-cab...I would be interested in what you come out with chalk-test wise though
I've been running my 285/75R16 Xterrains at 32psi front and rear.jtaco1 said:Like the title says, what are you guys running with these tires, I have them at 35 psi before they went on the truck. Seems to be working well, I still have to do the chalk test, but it is too wet out right now.
I had to go to 30 front and 28 back to get them to lay flat.jtaco1 said:Like the title says, what are you guys running with these tires, I have them at 35 psi before they went on the truck. Seems to be working well, I still have to do the chalk test, but it is too wet out right now.
Yeah, I even had to do pinch weld mod but no rubbing now.whtzep said:i was wanting to get the same xterrain tire do you have to lift it so much without rubbing? pete
