You will rub the frame at full lock. You may rub the upper A-arm with the tire sidewall, especially when aired down. You will rub the fenders a bit under compression but it is liveable. I ran that setup for three years with no wheel spacers.sr54x4 said:I would like to run my stock steel wheels with 285x75x16 Kumho Venture MTs. With 3" lift on a reg cab will I run into any rubbing issues? If I need to run a wheel spacer, what studs do I run on an 03 4x4?
John
The a-arm clearence varies quite a bit from tire to tire. I could not have put a nickel between my tire and the a-arm with the stock wheels. The sidewalls rubbed all of the paint off the arms but I never noticed any wear on the tire. I was keeping a REAL close eye on it after I noticed the paint was gone on the arm.Jay04Taco said:Yea, the rubbing he described is right, i have the same size tire, and i rarely rub the upper a arm though...........Aired down, theres not much eveidence of much contact on the a arm.......................but im sure it does, i have enough room to put 2 fingers between my a arm and my tire, but i have not gotten an alignmetn yet, sicne my lift, cause i will be getting uniball a arms soon.
I just made the switch to 4" BS. I have plenty of room between the sidewall and the a-arm and do not rub the frame at lock. I am getting a lot more rub in the pinchweld area. It was liveable before but I'm going to have to put the hammer to it before I hit the woods again.cartman308 said:so te biggest issue isn't the pinchweld? if you run aftermarket wheels with 3.25-4" of BS will that alliviate most rubing issues with 285/75???
2 fingers? LOL uh...that will change when yu get the thing alignedJay04Taco said:Yea, the rubbing he described is right, i have the same size tire, and i rarely rub the upper a arm though...........Aired down, theres not much eveidence of much contact on the a arm.......................but im sure it does, i have enough room to put 2 fingers between my a arm and my tire, but i have not gotten an alignmetn yet, sicne my lift, cause i will be getting uniball a arms soon.
I'm getting those same tires on my truck on a set of wheelers black steel wheels next week. I'm going to Demello to get a 4" procomp lift installed first though. I'll let you know how it turns out.sr54x4 said:I would like to run my stock steel wheels with 285x75x16 Kumho Venture MTs. With 3" lift on a reg cab will I run into any rubbing issues? If I need to run a wheel spacer, what studs do I run on an 03 4x4?
John
Careful if you trim too much of the plastic on the newer tacos. I trimmed a bit too much on the rear of the front wheel wells to get at the pinch weld. This opened up a passage for dirt/debris/whatever to get from the front tires to inside the fender and to my door jam area. After wheeling I was getting large stones, etc, in the door jam. I had to rivit in a new piece of plastic to fix it. Just something else to think about.Jay04Taco said:That should, except for the rear bolt on the fender flare when bound up, and maybe an occasional rub onthe front plastic minor trimming should aliviate that.
good point.Ursidae69 said:Careful if you trim too much of the plastic on the newer tacos. I trimmed a bit too much on the rear of the front wheel wells to get at the pinch weld. This opened up a passage for dirt/debris/whatever to get from the front tires to inside the fender and to my door jam area. After wheeling I was getting large stones, etc, in the door jam. I had to rivit in a new piece of plastic to fix it. Just something else to think about.
I think you want less BS like 3.5" or so.cartman308 said:I'm planning on an OME front lift (882/n85) that will give me about 2.5 inches of lift and a downey 2.5" aal in the back. If i buy rims with 4 1/4" bs would i have rubbing issues on the uca?? how bout the pinch weld? Would 4" bs be a better idea? I'm considering 285/75 IF the rubbing wouldn't be to bad. I like some of the ION wheels but they only come in 4 1/4 bs...... Eagle Alloy 186s come in 4" of bs.
I would try 15x8 but don't want to deal with the hassle of returning the rims if they don't fit........
or should i just scrap the 285/75 idea and stick with 265/75???????
thanks for the opinions
With 2.5"s of lift and those size tires you will rub...if you move out the back spacing to 3 5/8 you'll rub less maybe not even at all on the frame or the upper arms but are more likely to hit around your fenders/pinch weld. I have 4" backspacing with a 3" lift with the 285's and rub at full turn on the frame and rub the fenders in the rear. I've cut and trimmed and kept it now down to where it is minimal, but I do still rub. Just to little lift for that big of tire. You could do a 33x10.5/15 or a 255/85/16, both of which are narrower tires and help eliminate some of the problems...not to mention you might have to re-gear. I have the auto V6 and it's "tolerable" but not "optimable". Good luck.cartman308 said:I'm planning on an OME front lift (882/n85) that will give me about 2.5 inches of lift and a downey 2.5" aal in the back. If i buy rims with 4 1/4" bs would i have rubbing issues on the uca?? how bout the pinch weld? Would 4" bs be a better idea? I'm considering 285/75 IF the rubbing wouldn't be to bad. I like some of the ION wheels but they only come in 4 1/4 bs...... Eagle Alloy 186s come in 4" of bs.
stick with the 265s and you might not have to regear. you can also run them on stock rims.cartman308 said:I'm planning on an OME front lift (882/n85) that will give me about 2.5 inches of lift and a downey 2.5" aal in the back. If i buy rims with 4 1/4" bs would i have rubbing issues on the uca?? how bout the pinch weld? Would 4" bs be a better idea? I'm considering 285/75 IF the rubbing wouldn't be to bad. I like some of the ION wheels but they only come in 4 1/4 bs...... Eagle Alloy 186s come in 4" of bs.
