if I order and install 2wd leaf springs into a 4wd truck will it lower the rear? will it work?
just want the truck to be level looking for 2 inch ish drop in the rear. probably going to order them and see what happens everyone can learn from my experience then2WD springs for 5 lug trucks were designed for spring under. That was how they got the lower stance. I can't say for certain, but the springs for 2WD and 4WD were similar, but I don't believe they were the same (arch, length, etc). So depending on your plans for height, a spring under conversion would possibly be your best option.
Why not add lift to the front instead of lowering the rear?just want the truck to be level looking for 2 inch ish drop in the rear. probably going to order them and see what happens everyone can learn from my experience then
the leafs in back are already bad at least driver side so they need replacement anyways. money I am 18. don't want to put added stress on front end parts such as CV axle because it is a very old truck. also just more of a lowered kinda guyWhy not add lift to the front instead of lowering the rear?
