1 - 19 of 19 Posts
ok so ill be driven at a steady rpm them my intake sounds like its sucking air different than normal, then it will start hesitating bad ill giv it more gas then it goes away until i have it steady again. it also feel like it lacks power when it does that. got any ideas???
Dude. Complete sentances... *wink* It's kinda hard to read your question. ;)
LOL so edit it silly. (Just giving you a hard time btw.. Troy and MrDoug have been getting so much crap it was time to re-direct it) Hopefully one of them will know more of what your engine trouble is.
have you cleaned your throttle body and maf?:D
Certain speeds, or any steady speed?
Acceleration from a stop is normal?
When was the last time you did cap, rotor, plugs, wires, timing?
I think I would start diagnosing an ignition problem then.... I have had plug wires not last a year due to the heat buildup in the engine bay. I go through 1 ignitor a year due to heat soak issues (that creates vapor-lock type symptoms).
About now is when thefatkid comes on and makes me look like a fool by telling you exactly which part is going bad and how much.
One thing I just thought of ... steady speed is closed loop - could be a bad O2 sensor, it takes A LOT to throw a CEL on our motors.
1 - 19 of 19 Posts
