Hi everyone,
I am just finishing up a valve clearance adjustment on my 99 3.4 auto, 126k miles. I did a lot of searching for information on the forum and elsewhere before I got started, and didn't find much information, so I thought I'd offer some insight (and pictures soon hopefully) on the procedure and results. I run Mobil 1, and have since break-in, which may or may not affect the rate of valve clearance change. But of the 24 valves, only 7 were out of spec. When I pulled the shims on these 7 valves (this engine is a shim & bucket design, fyi), they were remarkably unworn. Where the cam lobe rides the shim, you can still see some manufacturing markings! I don't know if this is common or not, but in my experience there is usually some visible wear on the cam - shim interface, so I was happy with what I saw. I did not use a shim removal tool either, so it's not required though it would make the job easier. If anybody needs information on this prodedure, let me know.
Scott
Scott
