pulser said:
I am going to need to but a new lift on my truck soon and I want a 3in full leaf pack in the rear. I have a cap and I use the truck for work so I need extra white capacity. I have a 2 ½ ProComp add a leaf in the rear that has sagged to almost stock height.
you can have you OE leafpks rebuilt with added leaves and the whole thing re-arched for up to 3" of lift. One extra leaf will give you about a 500# increase in load cap. for more than 3" with OE or OE replacements like NWORs add lift shackles.
Whatever you get you won't have a 'full 3"' when you load it up unless you go with some sort of custom set. Check with David Hale on the Cali board for more info on that.
I've had the nwor hd pks for about 2 1/2 years now and just recently had to have them re-arched due to so many 1-ton+ loads of firewood
check with nwor as they may still have some of their Dcab hd springs on blow-out sale. they will tell you they are not for excabs but they are the same length, just a little heaver duty.
whatever you get make sure to get long enough shocks for whatever amount of lift you wind up with, axle wedge shims to get your pinion angle back to 0 degrees, a BPV extention bracket (if you like having rear brakes) and a 24" rear brake line.
