1 - 3 of 3 Posts
Hey, so I'm trying to decide what size to use for my 95 Toyota Tacoma 4 wheel drive I will have a 3 inch lift and trying to get the biggest tire I can to fit in there without rubbing when flexing. I have my eyes on 305 75 r16 and also 33x12.5 r16. I would like to see if any of y'all have this tire size on your Tacomas and see how they look like and tell me if you have to do any trimming or modifications to fit 305/75.
The most you'll fit with 3" of lift is 33" tires. You can stuff more, but you'll have to pound in the rear fender well quite a bit.
I'm running 33" tires on my '95 Tacoma with 2.75" of suspension lift and 1" body lift.
Don't forget you'll probably want to re-gear, especially if you have a 4cyl engine. I'd recommend 4.56 or 4.88 if you want lower gears for rock crawling.
Ya I see, I was thinking staying with the 33s also.
I have 4.10 gears on it, I think I'll be fine with it and just doing 3 inch lift also might do a 1 inch body lift later on
1 - 3 of 3 Posts
