will a 32x12.5x15 BFG A/T KO tires fit with 15" rims 3.75 backspacing with 3" suspension lift and 2" body lift? with little rubbing? i'm not worry about the full flex...
I think you mean a 32x11.50 or a 33x12.50? BF Goodrich doesn't make a 12.5" wide 32" All-Terrain.04RedLobster said:will a 32x12.5x15 BFG A/T KO tires fit with 15" rims 3.75 backspacing with 3" suspension lift and 2" body lift? with little rubbing? i'm not worry about the full flex...
That should be pretty good. It should only rub when wheeling, and won't be nearly as bad as my truck. My bed is dented from the rear tires stuffing hard.04RedLobster said:oh yeah that's what i meant...the 33x12.5x15 with 3.75 backspacing with 3in suspension lift and 2 in body lift, that shouldn't rub that bad right?
that will work fine. you'll rub a little off road and maybe on full-lock turns on the street but it won't hurt anything. Besides, if you ain't rubbin' some, you ain't tryin' hard enough04RedLobster said:oh yeah that's what i meant...the 33x12.5x15 with 3.75 backspacing with 3in suspension lift and 2 in body lift, that shouldn't rub that bad right?
