Hytenor would be the expert on gearing, he will post here in a minute.lol!
i would go with 4.88's if 33's is as big as i was gonna go.
not really, you would want at least 6" of lift for 33's.EricR said:I've searched around and found my answer on the tire fitment - looks like 3" of lift and 33's do not go together![]()
I've got 33's and 4.56's with the V6. For you and you 4cyl I'd go 4.88's for sure. I wish I had 4.88's.EricR said:I have a 03 Reg Cab 4x4 4cyl 5sp. It did not come with 4.10's from the factory, but some 3.something. It did come stock with tiny little tires.
I have already gone to 15x8 AR767 Black Steelies, and 31x10.5's - a Cornfed 3" lift - and put on some fenderflares. The truck looks pretty good.
I want to go 33's. I know I will have to regear - the truck won't even pull my jetski very well with the 31's. According to National Tire, 33's will fit with 3" of lift - but I'd like the have the input of people that have actually done it!
Any idea on what gearing to go with? 4.56?
Thanks for all the information!
If you like those fender flairs, I'd get more lift or keep away from 33's. i have 4.5" of lift and have some seriouse issues with rubbing, pinch weld is flat and i now have to start cutting.EricR said:I have a 03 Reg Cab 4x4 4cyl 5sp. It did not come with 4.10's from the factory, but some 3.something. It did come stock with tiny little tires.
SteveO said:I've got 33's and 4.56's with the V6. For you and you 4cyl I'd go 4.88's for sure. I wish I had 4.88's.![]()
An '03 4x4 with tires smaller than 265/70s??? dang, that's the first I've heard of that. What size tires do you have?EricR said:I have a 03 Reg Cab 4x4 4cyl 5sp. It did not come with 4.10's from the factory, but some 3.something. It did come stock with tiny little tires.
I've got a 5spd. ....Steve4BYnTacoma said:Do you have the auto or the 5spd tranny?
Don't you have a credit card?EricR said:Thanks for the input guys, I offroad at best 6 weekends a year. As far as what my 03 4x4 reg cab 5speed *should* come with -- I actually just pulled out the window sticker to confirm. It came with 225/75/15's, I just re-visited the gearing code, it's 3.91. It was a bottom line truck with the only options being A/C, and 4x4.
Looks like to get up to 33's is just cost prohibitive -- getting to 6" of lift, and the gearing alone would be 3Grand or better.
I guess I better just like it the way it is!![]()
holy crap batman! and here I thought Toyota stopped putting out 4x4 trucks with the dinky tires, sheesh. I know the early, gen I rigs came that way but not the new ones....learn somethin' new everyday. I wonder if this is just a quirk with the reg cabs...EricR said:Thanks for the input guys, I offroad at best 6 weekends a year. As far as what my 03 4x4 reg cab 5speed *should* come with -- I actually just pulled out the window sticker to confirm. It came with 225/75/15's, I just re-visited the gearing code, it's 3.91. It was a bottom line truck with the only options being A/C, and 4x4.
with the v6 its a waste of $ to regear for 32s, IMO unless you have the AT and tow/haul a lot. 4.56s/33s and the v6 are great for the 5-sp or the AT. With the AT you can go to 4.88s/33s if you want more low-end and don't mind slightly higher hwy rpms. either will help gas mileage as well.d0wnf0rcec0ncepts said:what about v6 with 4.56's with 32x11.5x16 I guess thats about 275/70/16 I think. anyboby have this combo, work, not work?
with the AT it won't be too bad but you'll run much higher rpms at speed on the hwy. off the line will be greatd0wnf0rcec0ncepts said:I ask because I am about to convert from prerunner to 4x, and the diff I found already has 4.56's in it, for a good price, so I can just swap in the 4.56's in the rear to match. just wondering cause every other diff that I have come across so far had 4.10's and cost much much more than the one I allready found
