1 - 3 of 3 Posts
I cant tell you for sure. It would be a good idea to search if you havent already, there are sure to be others that have figured out the fitment issues for 33x12.5s on your year taco.
You will rub unless your crank coilovers up (roughing up the ride), trim away a lot of plastic fenderwell, and have the metal cab mount behind your tires towards firewall cut. I have had this done and I clear fine. Others have had minor rubbing. If the truck is mainly for street then your ok except while turning it will rub. If you wheel it you will rub a lot.
1 - 3 of 3 Posts
