So my stock cast exhaust manifold was severely cracked, I replaced it with a Pacesetter header, but the EGR bracket was clocked wrong and I couldn't install the EGR pipe. I deleted the EGR system, took the EGR apart to get the connector that plugs into the engine harness. I soldered a 10k ohm resistor across the blades and plugged it into the harness, but I'm still getting a CEL and throwing the EGR code. I checked with a multi-meter and I am reading 10k ohm resistance through the plug, so I'm not sure why it would still throw a code unless a 10k ohm resistor is the wrong resistance. Anybody have experience with getting rid of the CEL?
You might have to try some different resistance values to dial things in with the ECU. Higher resistance = lower EGR flow and lower resistance = higher EGR flow. You might try a 12k or 15k and see if that works. The 10k value seems to be the tried and true number that most have made work.
EGR Temp sensor:
At 50°C (122°F): 64 - 97 k Ohms
At 100°C (212°F): 11 - 16 k Ohms
At 150°C (302°F): 2 - 4 k Ohms
You could also try resetting the ECU to see if that will help it re-learn the maps and values differently.
So if you try different ohms to see it will work do you still have to use only a 1/2 watt or more will be needed?
