1 - 3 of 3 Posts
I just noticed something this morning. Ever since I have had the Dual Battery, locker, spots, winch fitted it seems that the vehicle has a starting problem. If the vehicle stands for more than 2 days it only seems to happen, else there is never a problem. The vehicle will start but then switch off almost imediately. It did it twice in a row this morning and on the third time it was fine. Else the vehicle starts fine without trouble.
I have had this happen when I disconnect the battery to work on it for a while but then the vehicle only does it once and never again.
Any help would be appreciated.
Manual transmission? With mine, sometimes the button behind the clutch pedal wouldn't make complete contact so when I turned the key, it would attempt to start, but then stop just as it was trying to take off.
I know this suggestion sounds obvious, but it's the obvious things sometimes that turn out to be the problem.
Otherwise, here's a bump...
1 - 3 of 3 Posts
