1 - 2 of 2 Posts
3RZ Turbo Stuff Coming Together
the header is built, setup for external gate (38mm), it's got a standard t3 flange. Going to use my hybrid (t3/t4) I was using in the ranger, tial bov and wastegate. This will be a simple install, about 6 lbs of boost, with some tuning it should make EST 220 ish.... Braided lines for everything, going to run an external oil cooler and tap for feed from there, and just tap the pan for drain. Need to find someone to tune it, this will be non intercooled setup with alky injection. I've got a welder and piping here, will build my own 3" exhaust and boost pipes. More info coming. Heres the turbo manifold finished.
1 - 2 of 2 Posts
