Basically everything left over when I swapped gears in the rear and diffs in the front. The truck had about 75K on it when I swapped gears. I have the entire front diff from a 99 v-6, 4.10:1, TRD tacoma and just the rear 4.10 ring and pinion (TRD V-6). Rear gears are worn perfectly since the factory tends to do a good job when they set up gears The front worked fine for me and i assume it will do the same for you. As I understand it the ADD diff can be used for manual hubs as well, just take off the solenoid. I want $100 for all of it+shipping or I'll meet you within reason since that diff is so damn heavy. Also, a trade for a wrecked streetbike + cash would do as well. I live in Suffolk, VA (SE VA) but go to school in Blacksburg, VA (SW VA). I will be traveling to New Orleans for the sugar bowl and could bring it then if you are anywhere on the way from Suffolk to New Orleans.
Ryan
Ryan
