has anyone else done the swap if so any pointers or lead pros or cons?
Sent from my DROID RAZR using Tapatalk 2
i did put a 92 4.3cpi motor into my 884runner 2yrs ago the best advice is try and find a complete donor. run a speedway motors universal chevy radiator size 22x19 pending on the lift on your truck you might not need to run a 2inch body lift the wiring isnt that hard but if you dont want to attempt than go with a painless harness or howell efi harness. take your time and do the research also i made my own motor mounts but you can use the ones from advanced adaptors
the engine i have comes with the brain and my rad. is gonna be mounted on the flat bed is there any other clearance issues? i heard you gotta use a chevy astro oil pan
im running a front d44 and am using the stock cpi oil pan and have clearance but you might have to trim the firewall pending on how far back you want the motor to sit but other than that no issues i can think of
