Any suggestions on what gears i should go with? 4.56 or 4.88? Most of the info on the truck is in the sig. Also, it is a 5spd. I want to be able to still do highway driving, Get better gas mileage than with the stock gears and have about the same amount of power as stock with figuring in, the weight of the extra gear with the bumper and sliders. I was leaning towards 4.56. Also, i may get a supercharger in the future too. Suggestions?
4.56 for sure, if you had the 2.7l i'd say 4.88 cause that's what i've got but you'd sit at like 3500 rpms going 70 w/4.88's w/your v6. 4.56 will give you good power and good mileage.
I believe i have 4.10, but not for sure. I can't find the vin number database thing to check for sure.
· Premium Member
That sounds right. Just curious. And you'll be fine w/ 4.56's.
There's an axle code on the drivers side door (or the pillar) and that'll tell you what you have. I don't remember where the chart is, but I'm sure you could search for it easily enough.
I'm set up just about exactly like you as far as motor/tranny/tires go and I'm gonna go with 4.56.
