I'm due up for a timing belt and wanted to know what is the usual replace items when doing so??
I'm guessing it's the normal stuff....Timing belt, Water pump, both pulleys and the tensioner? Is there anything else I should replace while I'm in there??
T-Stat, correct coolant, and drive belts.
Isn't the starter under the intake? If so, I'd change the contacts while you're in there.
Why would you remove the intake?
Getting to the starter is far more difficult than a timing belt and water pump.
Cross that bridge only when absolutely necessary!
Yeah no need to remove intake to do the t-belt.
What year is your Tundra? If it is non VVT-I, then I would exclude cam seals from this list unless they are leaking.
-Water Pump
Aisin WP kits will include WP o-ring,metal gasket, and upper flange o-ring, and t-stat o-ring)
-Thermostat
-Cam Seals
-Crank Seal
-Idler Bearing
-Tensioner Idler Bearing
-Tensioner (optional, use discretion. Must be removed anyway to compress and pin tensioner down)
-Timing Belt
-Drive Belt
