1 - 17 of 17 Posts
Anyone got one, I can borrow, or rent one?
what pipe material you trying to cut?
I figured that.
Sorry, I don't think my copper pipe cutter will handle that...hell, it just barely handles K copper.
Jessie & Ian did it w/a angle grinder w/a cutting blade on the show.
P.S. Dont tell 'em what U are cutting because most of those types of cutters are ment for soft copper.
That's a really good write up but how do you know when to stop cutting so that you don't hack through the knuckle?
Jesse & Ian new the thickness of the outer tube and were careful to only cut that deep.
Discussion Starter · #10 ·
I'm cutting a weld so I'm guessing it would be soft fill metal. Also once you could get it to turn you are through.
Discussion Starter · #13 ·
I'm still working on it and it's not just a twist.. A complete axle swap to FJ80 front axle.
I know I know but I'm really interested in the twist procedure since I have an xtra front housing (not FJ though) laying around. What's up w/your other axle?
Kyle, how much longer do you need the pipe cutter? I'll need to return them soon.
Discussion Starter · #16 ·
Funny I was about to call you to bring it back..
Ok, give me a call after work. How did your rotation go?
1 - 17 of 17 Posts
