1 - 3 of 3 Posts
I just modded a 4 runner map light into my taco and the lights are real dim. The lights are very dim and when both are on at the same time they are nearly visible, they both have 5 watt bulbs(the dome has 8). I first thought it was a bad ground but I have it wired directly to ground, I also have soldered and heat shrinked all connections.. anyone ever do this mod and have a similar experience...know a fix...thx..bals:)
Completely guessing here as I have never seen a 4-runner map light, but could the lights be in series instead of being in parallel?
I believe they are in parellel.....they are wired from the factory...the sub assembly...I imagine its correct...just does seem to be getting proper juice...
1 - 3 of 3 Posts
