1 - 13 of 13 Posts
Are there any pictures of a 1 or 2" RB body lift. I don;t mean just a picture of the truck but of upclose pictures of the Ultimate blocks and poly. bushings and heavy duty hardware all installed. Just would like to see the actual setup up close. WOuld appreciate very much. Also, what are peoples thoughts of the poly. bushings and Ultimate blocks? Thanks.
I've got a 2 inch body lift but sorry no close up pictures, I got the Ultimate blocks and stock hardware with mine and its been working great. If you are asking these questions because you might go with another body lift maker then you should know that rodger brown has the best ones out there on the market so you shouldn't have to worry about his quality.
· Don't get Wenzeled
http://s94741489.onlinehome.us/albums/truck_stuff/bodylift/
sorry for the crappy pictures... taken at night
this is a RB 1" inch ultimate blocks, poly bushings, heavy duty hardware, and a little mud from my last Gilmer trip :)
Thanks a lot. I noticed you didn;t have the bumper raised yet. Is that a pain in th ass to install? And over all how is the installation? Is it a solid setup and dependable? Was the gas line and issue? ARe there any othe issues that you had to change or modify after the lift was on? SOrry for all the questions, JUst want to know it all!!! Thanks
One more thing Nastnate . . . what are you running for a setup on your rig? Just the 1" body lift? ANy suspension? WHat size tires are those? Im assuming you have the green 99-00'? TRD with the rock sliders? Was looking at your website. I got the same truck. Am looking for what my truck will look like after my mods. ANyway, thanks.
yup, that's me. just was updating the site too :)
It's a 1" BL. No suspension lift yet.
The tires right now are 31" BFG A/T's, but I run 32" BFG M/T's when I'm off road, with little rubbing (removed mud flaps).
I haven't raised the bumper because I'm not sure if it's worth the time/effort/money. Besides, I'd like to get a different bumper anyway, so it'll be somewhat of an eyesore (at least to me) until I upgrade.
No real issues with the body lift since it was only a 1". I did have to unclamp some A/C crap on the left side under the hood so I wouldn't break the clamps, but that was it.
In hindsight, I should have gone with a 2". Just to give that little extra lift :) but if you do that, be wary of the issues that come with that (shifters, misc hard lines, etc.)
My goal at my current budget is to run 1.5 - 2" suspension, 1" BL with 32" muds. That should be capable enough for what I want to do... at this time
Just comes down to how much to want to spend (more than 1" and you'll probably have to spend more to make it work).
· Re-Member 9/11
I have the RB 2" on mine. The front bumper is not a big problem if you order the front bumper brackets from Roger when you order the kit. If you have an auto trans, the linkage is adjustable on the trans shifter, and the transfer case shifter does not need to be extended if you don't want to. I did not extend mine and it functions properly and does not look that bad.
Bill
1 - 13 of 13 Posts
