2001 2.7L Tacoma
Manual Transmission
Manual J-Shift Transfer case
How do I get my 4wd dash light to work after doing a SAS and removing the ADD actuator? I've seen posts on how to do it if you have the push button transfer case with the 4wd ECU, but I can't find anything for the j-shift transfer case.
I was hoping to be able to jump some wires on the ADD actuator harness.
Can you help decipher that for me? I'm terrible at reading wiring diagrams...
I've tried jumping some wires at the ADD actuator harness and got the light to turn on, but it stays on even when in 2wd.
So obviously jumping the 4WD light to ground will leave it illumated all the time since it would normally turn on and off as the ADD engaged or disengaged. I'd recommend using the 12v power from the 4WD switch on the transfer and use that to trigger a relay that closes the ground to power jumper on the ADD harness for the 4WD light. There isn't any other simpler way from what I can tell.
