1 - 2 of 2 Posts
I got an A340f trans that came out of a 4runner that came with a tcase. I got a manual tcase the other day and noticed a difference in shaft length to the trans. Questions are did I get the wrong tcase? Can I swap that part of the case to the shorter shaft? I did mount it to the trans but with measurements I have taken the longer shaft has to be coming in contact with the clip ring in the trans
The manual transfercase is longer because of the stick shift. It will mate up fine to the a340f. Where you will make up the difference is the half shaft. If i remember correctly they came in lengths from 31-33". You will need to shorten or lengthen yours accordingly.
1 - 2 of 2 Posts
