Pulled the tranny and xfer cae out to make room for my th350. Thought I would offer it here before I carry it to the scrap yard. And I really dont wanna mess with shipping.
Out of a 91 with 4cyl. Dont know the exact milage cause the odometer hung, but the xfer case is still really tight.
Can that transfer case be bolted to newer transmissions?
Dont beleive so. But I could be wrong. Neither leak oil.
post it over on toyotatrailriders.com i think one of the guys needed one. It wouldn't happen to be out or a turbo 4cyl would it? cause I'd probably buy it
Only with adapters. But you can take the transmission and case and bolt it in. You just have to use the 2.7 bellhousing. The only difference that I could find beteen the Taco trans and the P/U trans is the 3rd gear ratio. If you swap it in the shifter needs to be bent alittle since the P/U trans shifter it farther forward than the taco.
