no, 22re is a pre Tacoma (95.5) 2.4L 4 cyl. If you're looking at a 4 WD Tacoma, its either got the 2.7L I4 or the 3.4L V6.Thanks.
I've also read about a 22re. From what I can gather, thats the pre 01 2.7L. Is that correct?
there were some early tacomas with the 2.4 in it
The 2wd mini Tacomas were available with the 2.4L engine. All prerunner and 4wd models were either 2.7L or 3.4L from 1995-2004.there were some early tacomas with the 2.4 in it
roger thatThe 2wd mini Tacomas were available with the 2.4L engine. All prerunner and 4wd models were either 2.7L or 3.4L from 1995-2004.
Yeah, I do really like my 2.7L also. Both of my rigs have 2.7L's. They can be a bit hairy on the highway tryin' to merge into traffic, especially with big ass tires, but my little 2.7L tacoma will smoke my friends V6 ranger. And offroad I can put it in 4 Low, second gear and just putt around like its nothing.Haha, everybody here talks so bad about the 2.7. It's a great motor, especially for being a 4 banger. Hell, just tonight I ran mine for 170 miles and it's sitting on a little under 3/4 of a tank. It's got plenty enough power for the average joe schmo...the only downside is you have to re-gear if you run any kind of bigger tires or lift. Besides, the 3.4 has only got 40 more ponies sitting in it coming from the factory.
I'd take my 2.7 over the six anyday....but that's just me.
"only" 40 hp - but it also makes it's power lower in the RPM range.Haha, everybody here talks so bad about the 2.7. It's a great motor, especially for being a 4 banger. Hell, just tonight I ran mine for 170 miles and it's sitting on a little under 3/4 of a tank. It's got plenty enough power for the average joe schmo...the only downside is you have to re-gear if you run any kind of bigger tires or lift. Besides, the 3.4 has only got 40 more ponies sitting in it coming from the factory.
yeah. and it maintains it too. not to mention the SC does wonders."only" 40 hp - but it also makes it's power lower in the RPM range.
Timing chains are a no-maintenance item that will generallly last you throughout the life of the vehicle unless the chain guides wear out(which pretty much doesn't happen on most newer cars since they stopped using synthetic/plastic chain guides in the late 80's/early 90's which used to wear out sometimes during cold engine-starts and the chain would rattle like crazy before and eventually cut a hole in the side of the block if not replaced in a timely fashion).Thanks all for the info.
Partyman What is the benefit of having a timing chain? Give me a 2 stroke dirt bike and I can work wonders, put a truck in front of me and hope i dont break something.
partyman66;935535- said:Early Model 5VZ Engines made between 1995-1997(maybe as late as '98) had some serious issues with Head Gaskets failing... I think there was a recall to fix this on those specific year motors.
Both motors are really durable and have a reputation of being bulletproof.
