1 - 2 of 2 Posts
ok my question is could i install 62" deavers with new mounts and rear shackles without going wih a longer shock for a while or should i just save up and get my rear cage done for the new shocks? im sure that the new mounts of fronts springs and shackles would lift my truck a bit, and longer shocks are required but im just wondering. any input would be appreciated. thanx guys
david
david
im going to assume you are mounting them spring under....you have to get rid of the lower shock mount location....so no you couldnt use them.....if somehow u ghetto riged it to keep the stock shocks, then yes you could....they would become limit straps...and you would end up destroying the shocks very very very fast.....save up and do it right the first time....not the thirty first time
1 - 2 of 2 Posts
