1 - 13 of 13 Posts
What would be better in your opinion?
Ride quality, cost and flex are the main issues. I will be having the work done at a local shop, so from what I can tell it's going to cost about the same either way. I have a Fabtech 6" installed and need to get 6" of rear lift.
I'm no expert on the 63" Chevy's but I think they only give you like 2".....a custom pack can give you whatever lift you want...Or rebuild your current pack by adding 2 cut-down stock leafs from another set and a cut-down aal, that and a small shackle will get you there i think.....the rebuilt packs are supposed to give 4" over stock...i think. you can read about it on mor4wd.com in the mods section
Long lost Taco Owner
I did the chevys for price reasons but they also ride and flex very well
Gamblur said:
what size shackles did you go with to get the rear level with your fabtech 6"?
6" eye to eye will get you about even in the back. I have a 9" eye to eye shackle and I am even with ~ 7" of lift
I love when people like you give opinions. :D
Ban Count: 12
Oh no... I know what's coming up next... :rolleyes:
When you are looking for 2" of lift in the rear, put in a set of 63" chebbies and see how much you get. :bitchslap
Do we still need to use blocks. If so where do we get these blocks from?
4xbrian said:
Did you relocate the shackle or do the double shackle setup?
I just used a longer then stock shackle. No need to relocate the rear shackle mount. To get a better shackle angle I could move the rear shackle 2-3 inches but I also have a 9" eye to eye shackle. If you use a 5-7" eye to eye shackle your angle should be fine.
My question is, with the Chevies, do I still need blocks? I have a Fabtech and wanting to get rid of the blocks. I have read some people use CHevies and still have to use blocks to get the lift they want.
1 - 13 of 13 Posts
