Ok, so I'm trying to replace my accelerator cable in my truck with no luck, truck was originally an 84 4x4 with a 22r that got wrecked, cab was replaced with what I believe was an 85 model 2wd cab, I don't remember if the throttle cable was transferred over from the orig cab or if the 85 2wd cable was used. Recently the motor was put in and 85 4x4 truck that originally had a 22re in it, accelerator cable was swapped and everything worked fine, now I'm needing to replace the cable and I'm finding it impossible to find, need help and or pics of y'all's throttle cable/bracket because something is not right here!!!
iirc, one was longer than the other…or maybe the 89-95 was longer than the 84-88. I think the efi one was longer though and you had to make your own bracket work on the 22r head if you didnt buy the adapter bracket(swapping on aftermarket carb).
You'll probably just need the efi cable from an 84-88.
The efi cable from the 85 was waaaaay to long, forgot to add that the truck has a weber carb installed
